Vanishing Door Frames
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-02-01
03:51 PM
‎2023-05-24
10:56 AM
Rubia Torres
‎2010-02-01
03:51 PM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-01 03:58 PM
‎2010-02-01
03:58 PM
What version of archicad are you using? What operating system?
If you have AC12 or higher there is a partial structure display setting. Check that to see if it is the issue.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-01 05:47 PM
‎2010-02-01
05:47 PM
Did you change your floor plan scale?
If your doors are set to have a scale sensitive display, this can "simplify" the symbols.
ArchiCAD 28 USA Full and ArchiCAD 22 & 7
Windows 11
Windows 11
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-01 10:33 PM
‎2010-02-01
10:33 PM
I'm using ArchiCAD 13 on a mac. I tried changing my Partial Structure Display but it was already set to Entire Structure.
I did change the scale from the 1:48 that the default was set on to 1:100. How would I fix the display if that was the issue?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-01 10:40 PM
‎2010-02-01
10:40 PM
Ok, so I found the 2D representation option (it was set to scale sensitive) but now my door tool isn't working at all. After the first click to select a centre-point or corner no white space appears in the wall as a place to put the door. How do I fix this problem?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-02-02 02:00 AM
‎2010-02-02
02:00 AM
Can you select the wall? Without any more information, it kind of sounds as though you may have activated the evil Snap Grid (this is easy to do with the default settings - just hit "S").
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
