Visible lines disappearing
I am using the PROFILER to create column dressings and coping these column bases to other columns. Everything looks fine in all windows except in Section/Elevation & 3D Hidden line some of the visible lines disappear! Any reason why?
Thanks
5 REPLIES 5
Djordje
Set your contours to Best.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I have changed to BEST and still the same rezults. Any other solutions?
Thanks,
Joseph
Dave Jochum
I have similar problems consistently, but most often in S/E windows where the "contours" setting is not relevent. Attached is a current example. The half circle is an elevation of a ball. When viewed from a side elevation, it renders properly.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Could this behavior be because of line width? I have tried using .5 mm instead of .18 mm for the PROFILER. It seems to work in Section/Elevation & 3D.
Sorry whit a closer look I see that it does not work in section/Elevation widows. So the question still remains?
Joseph
