2004-02-18
03:22 AM
2023-05-24
12:50 PM
Rubia Torres
2004-02-18 06:58 PM
Joseph wrote:Set your contours to Best.
I am using the PROFILER to create column dressings and coping these column bases to other columns. Everything looks fine in all windows except in Section/Elevation & 3D Hidden line some of the visible lines disappear!
2004-02-20 09:32 PM
2004-02-21 06:22 AM
Djordje wrote:I have similar problems consistently, but most often in S/E windows where the "contours" setting is not relevent. Attached is a current example. The half circle is an elevation of a ball. When viewed from a side elevation, it renders properly.Joseph wrote:Set your contours to Best.
2004-02-23 09:19 PM
2004-02-23 11:54 PM
