‎2014-11-17 11:51 AM
‎2014-11-17 04:06 PM
‎2014-11-19 01:20 PM
‎2014-11-19 08:39 PM
‎2014-11-21 09:37 AM
‎2015-01-21 01:57 PM
‎2015-01-21 10:06 PM
DGSketcher wrote:Hi.
Thanks for the pointers lazlo but page 368 isn't very helpful if you aren't familiar with the syntax or data structure.
DGSketcher wrote:Challenge accepted!!!
Anyone able to shed any more light on this with a simple worked example of grabbing a single predetermined IFC parameter's value for use in a label?
HOTSPOT2 0,0
CIRCLE2 0,0,0.10
idstring=1
shortName=2
longName=3
!===FOLDER NAMES=====
DIM folderNamesArray[] !<-- array will hold 3 entries per folder: idstring, shortName, longName
!-- main folder only has idstring, short and long name are empty
n = APPLICATION_QUERY ("OwnCustomParameters", "GetParameterFolderNames()", folderNamesArray) !<-- n = quantity of folders * 3 (includes main/root folder)
DIM folderShortName[]
FOR i=1 TO VARDIM1(folderNamesArray)/3
folderShortName=folderNamesArray[3 * (i-1) + idString]
NEXT i
VALUES "folders" folderShortName !OR folderNamesArray !<-- which displays all values of array in parameter "folders"
foldersInTagsAndCats = n/3 !--or VARDIM1(folderNamesArray)/3
!!!PRINT folderNamesArray
!!!PRINT foldersInTagsAndCats
FOR i=1 TO n
TEXT2 0,0, folderNamesArray
ADD2 0,-0.75
NEXT i
DEL n
!===PARAMETER NAMES=====
DIM parNamesArray[] !<-- array will hold 3 entries per parameter name: idstring, shortName, longName
n = APPLICATION_QUERY ("OwnCustomParameters", "GetParameterNames(" + folders + ")", parNamesArray) !<-- middle part "GetParameterNames...+...+..." between commas should work out as a whole string
DIM paramNames[]
FOR i=1 TO VARDIM1(parNamesArray)/3
paramNames=parNamesArray[3 * (i-1) + idString]
NEXT i
VALUES "params" paramNames !OR parNamesArray !<-- which displays all values of array in parameter "params"
!===PARAMETER VALUE=====
parValue=""
n = APPLICATION_QUERY ("OwnCustomParameters", "GetParameter(" + params + ")", parValue) !<-- middle part "GetParameter...+...+.." between commas should work out as a whole string
VALUES "value" parValue
Floor plan will show all folders from the objects Tags and Categories tab.‎2015-01-21 11:45 PM
‎2015-01-22 01:22 PM
‎2015-01-22 04:16 PM
ADD2 0.50,0 TEXT2 0,0,value DEL 1to show the selected value.
