Check your Doors for Fill parameters where the parameter says: "Missing".
Try to find a Door with which the error comes during 3D conversion.
Open its settings dialog and look over the parameters to find the problematic fill parameter. Set it to a fill that exists in the file. Then the 3D conversion should be fine.
If that's OK, then you will need to find all other problematic Doors in a similar manner.
