Was Stretchy, Now It's Not
In an earlier version of the code shown below, you could stretch length A using one or the other of the hotspots shown in red. In the process of making a few changes, this functionality went away. I have tried everything I can think of to get it back. I didn't program this behavior in the first place, it just worked. Help!
100: !!DEFINE TEXT STYLE
DEFINE STYLE "AC_STYLE_1" pTextFont, pTextSize / 2.54, 5, 0
SET STYLE "AC_STYLE_1"
110: !!DRAW GRID LINE AND HOTSPOTS
PEN pLinePen
LINE_TYPE pLineType
HOTSPOT2 0, 0
HOTSPOT2 0, A / 2
HOTSPOT2 0, -A / 2
LINE2 0, -A / 2, 0, A / 2
HOTLINE2 0, -A / 2, 0, A / 2
120: !!ADD FIRST BUBBLE
ADD2 0, A / 2 + (pBubSize * GLOB_SCALE)
GOSUB 200
DEL 1
130: !!ADD SECOND BUBBLE IF REQUIRED
IF pBubLoc = `Both Ends` THEN
ADD2 0, -A / 2 - (pBubSize * GLOB_SCALE)
GOSUB 200
DEL 1
ENDIF
BODY -1
END
200: !!BUBBLE
LINE_TYPE pBubLineType
PEN pTextPen
ROT2 -SYMB_ROTANGLE
TEXT2 0, 0, pBubNum
DEL 1
PEN pBubPen
CIRCLE2 0, 0, pBubSize * GLOB_SCALE
HOTARC2 0, 0, pBubSize * GLOB_SCALE, 0, 360
HOTSPOT2 0,0
HOTSPOT2 0,pBubSize * GLOB_SCALE
HOTSPOT2 0,-pBubSize * GLOB_SCALE
HOTSPOT2 pBubSize * GLOB_SCALE,0
HOTSPOT2 -pBubSize * GLOB_SCALE,0
RETURN
11 Replies 11
Matthew stated the way it works. When you grab any hotspot, ArchiCAD checks whether there is any hotspots in the Object that is at a distance of A in the horizontal direction. If there is any, the object will be stretchable in the horizontal direction.
Similarly, it checks whether there is any hotspots in the Object that is at a distance of B in the vertical direction. If there is any, the object will be stretchable in the vertical direction.
If you add another hotspot:
rect2 0,0,a,b
rect2 0,0,a*.5,b*.5
hotspot2 0,0
hotspot2 a*.5,b*.5
hotspot2 a,b
hotspot2 -a*.5,-b*.5
then the hotspot at a*.5,b*.5 will also be stretchable in both directions.
But if you do the the following:
rect2 0,0,a,b
rect2 0,0,a*.5,b*.5
hotspot2 0,0
hotspot2 a*.5,b*.5
hotspot2 a,b
hotspot2 -a*.5,b*.5
the hotspot at a*.5,b*.5 will be stretchable only in the horizontal direction as there is another hotspot that is at a distance of A in the horizontal direction (-a*.5,b*.5), but there is no other hotspot that is at a distance of B in the vertical direction.
Thanks for the information on adding the additional hotspot. I was unaware of the effect it would have. So, basically, in order to have multiple strechable points based on "A", it requires more than 2 hotspots.
I have been using the diamond spots for strechable points, but this may be a simpler approach for some of the objects I'm working with.
