ā2016-03-05 02:16 AM
ā2016-03-08 05:06 PM
ā2016-03-08 05:24 PM
laszlonagy wrote:
Which part specifically, of said jubberish?
It would be kind of long to explain all, and I guess you only have issue with part of it.
ā2016-03-08 08:07 PM
Duplicated database name "ArchiCAD_Library"There are probably duplicate library parts in your libraries. If you go to the Library Manager and remove all your duplicates from your libraries then I think this message will disappear. You won't even need to know what it means.
at line 2 in the 2D script of file MASTER_GDL_ArchiCAD_Library.gdl.
ā2016-03-08 08:10 PM
ā2016-03-08 09:37 PM
rob2218 wrote:ARCHICAD cannot consolidate them because it doesn't know which version you need. Only you know that and only you can decide that. So unfortunately, this will remain in the realm and responsibility of the user, I suspect.
Thank you.
I'm always nervous to "remove duplicate' library parts cause I'm always thinking I'm removing that one part that something in the file is looking for and when I remove "that", then it makes it even worse.
Wish there was a "consolidate duplicate library parts" command so that all objects that were the same could be merged into 'one'.
ā2016-03-08 09:40 PM
rob2218 wrote:On the contrary, you should be nervous when there ARE duplicates. In that case you never know which version ARCHICAD is using. Let's say two versions have two different 2Ds. You think one is used but the other is used and you don't check. Then the documentation goes out and turns out the other version is used in it.
Thank you.
ā2016-03-08 10:54 PM
ā2016-03-08 11:07 PM
ā2016-03-08 11:18 PM
laszlonagy wrote:
We disagree on this. I think it is important to make time for these kinds of things to put the project file in good working order and keep it that way.
I remember I once looked at another person's PLN file who was also working in our office. I was also a file coming from earlier versions, went through a few people, stuff like that.
The file was only a few megabytes, but it took minutes for it to open.
Started to check things and it turned out its libraries were a complete nightmare, multiple versions of the same library loaded, lots of duplicates, etc. Took about 1.5-2 hours to clean it up but after that the file open in fraction of the time and performed much faster afterwards.
Just think of how much time it wasted for all those people who did not have the time to clean it up. And then I am not even talking about the inability to tell which version of duplicates will be used.
So I do believe one should find the time to keep Project files in good order.
