alemanda
IES LAMPS - read data from ies file
I'm trying to read some basic data from IES file (for example the Power Consumption) using OPEN, INPUT commands but I cannot get the wanted result.
Watt value is stored in the 9th row, 3rd field ...
This is the simple code I'm using
  • ch1 = open ("TEXT", "3010216.ies", "Separator = ' ',mode=RO, LIBRARY" )
    n = INPUT (ch1, 9, 3, test)
    print n, test
    close ch1
"test" is a text variable.
print command returns always -1 value (end of file).
Where do I make mistake?
This is the IES file
  • IESNA:LM-63-1995
    [TEST] 3010216
    [MANUFAC] 1000
    [LUMCAT] 3010216
    [LUMINAIRE] Flamingo applique 9W (LED - 3000K)
    [FLASHAREA] 00475
    TILT=NONE
    1 730 1.0 19 1 1 2 -0.050 00 00
    1 1 9
    0 5 10 15 20 25 30 35 40 45
    50 55 60 65 70 75 80 85 90
    0
    84.53 84.53 83.44 81.91 79.28 75.77 71.61 67.01 61.76
    55.63 49.06 41.83 33.94 26.28 17.52 8.76 1.53 0 0
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
0 Replies 0
