2023-04-18
10:52 AM
2023-05-24
12:46 PM
Rubia Torres
I made custom PARAM-o object and want to share with Archicad users for free. What is right way to do that ?
Solved! Go to Solution.
2023-04-18 11:26 AM
Did you try adding it here? I am curious to know if it works. It would be a good starting point.
2023-04-18 12:19 PM
Good idea. Will try to upload in separate Tread.
2023-04-18 02:00 PM
I never had time to play with Param-o, but I believe it must have equal functionality to Archicad GDL editor in terms of licensing:
If you want to share your work with other users for free, you need to put it under the Public Domain Dedication 1.0.
As for sharing such library parts you can publish them here or on BIMcomponents.com.
| Archicad 4.55 - 26
2023-05-26 07:55 AM - edited 2023-05-26 07:56 AM
This is stretchable snow guard element for roofs with clay tiles.
It have several settings that can be predefined shown in Custom Settings picture.
If its not enough object it self can be edited.
Object consist of these files inside Compressed (zip) folder: Snow Guard.prmo - Param-o file (Import via Param-o manager) Snow Guard hanger Profile.xml - Snow Guard hanger Custom profile (Import via Attributes...) Loading instruction:
2023-05-29 05:08 PM
Hi Algimantas
Amazing, I will take a look and I will let know how it works for me.
Thanks in advance and all the best.
2023-05-30 07:56 AM
Thanks,
Good and Bad feedback is always welcome 🙂 This is my first parametric Archicad object in my 19 years of Archicad experience 🙂
