2024-01-19
01:09 AM
2024-01-20
06:29 PM
can someone please tell me why i can't get my change ID's to show what i've named them? when i place a new change marker i add a change id, in this example CH-08. and when i place the maker it shows CH-08 in the view. in the change manager it shows CH-08, when i look at the drawing in the layout book with the transmittal set still open the marker shows 05-WIP1, when i close the transmittal set the marker in the drawing shows 051. and my revision history object shows the change ID as 051. i really have no idea what's going on.
Solved! Go to Solution.
2024-01-19 03:49 PM
heathldesign:
One thing to check is the Book Settings > Numbering of Changes in Revisions > Use Change ID.
David
2024-01-19 03:49 PM
heathldesign:
David
2024-01-19 06:22 PM
you da man! thanks David. that has been plaguing me for years and just haven't had the gumption to deal with it.
2024-01-21 02:23 PM
So many settings, so little time. Good to know that worked for you.
David
