What is going on with my change ID's?
heathldesign
can someone please tell me why i can't get my change ID's to show what i've named them? when i place a new change marker i add a change id, in this example CH-08. and when i place the maker it shows CH-08 in the view. in the change manager it shows CH-08, when i look at the drawing in the layout book with the transmittal set still open the marker shows 05-WIP1, when i close the transmittal set the marker in the drawing shows 051. and my revision history object shows the change ID as 051. i really have no idea what's going on.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.1. AC 27, 6000 USA
David Maudlin
heathldesign:
One thing to check is the Book Settings > Numbering of Changes in Revisions > Use Change ID.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
heathldesign:
you da man! thanks David. that has been plaguing me for years and just haven't had the gumption to deal with it.
So many settings, so little time. Good to know that worked for you.
