LeeJaeYoung
What is the thick black line on the cross section of the door?
1. Enterance door 25
2. Style 1
I can't find it. ^^
this is detail view.
I deleted one outline.
It had these things in it.
This image was opened 4 days ago.
AC27 on window 11
1 Solution
A_ Smith
Looks like it's "opening lines" you need to disable at door settings or MVO
AC 22, 24 | Win 10
Go to post
4 Replies 4
A_ Smith
AC 22, 24 | Win 10
LeeJaeYoung
thank you so much ^^
AC27 on window 11
LeeJaeYoung
But why does this happen? Why does the opening line affect 3D?
AC27 on window 11
The opening lines are set to show in 3D.
Seems on one side they are dashed and on the other side of the door they are solid.
Because they show in 3D, they also show in elevations and sections.
Your section cuts through the door, so you are only seeing part of those opening lines.
