PH Architecture
Who ate the Archicad Model Library
The library that came with 28 is missing all of the standard US components. It appears to be just furniture.  Supposedly there is a method to return to the US library but there is no information as to how to load this library.  Is anyone else having this issue or is no one using 28?
Operating system used: Mac Intel-based
Setup info provided by author
31 Replies 31
Jeff Thompson
We're getting this a lot this week.  Here is my answer to a previous question.  Let me know if this helps.  You need to load the Archicad Legacy Objects library pack.  C:\Program Files\GRAPHISOFT\Archicad 28\Archicad Legacy Objects.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Eduardo Rolon
If you use Medicine Cabinet 27 on any of your projects you will need to save it out to your own library. GS in their wisdom decided that nobody uses it and if they want to then you could spend some extra time configuring one of the cabinet objects. Obviously as long as you don't mind the knobs moving when you change sizes.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Oosh
I just added the Archicad Legacy Objects and am still missing a number of objects including the following critical ones:
  • W Column
  • W Beam
  • DET_Stud
  • DET_CMU
Is the Archicad Legacy Objects library complete?
AC26 5004 | MacBook Pro (16-inch, 2023) | Sonoma 14.0 | Apple M2 Max | 32 GB RAM
David Maudlin
Oosh:
See this thread: Archicad 28 Detailer Library.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Oosh
Thank you, David! I was able to find DET_Stud and DET_CMU objects among the Archicad Legacy Objects.
Unfortunately, W Column and W Beam are still nowhere to be found. I exported those objects from AC27 and loaded them into the embedded library for now, but that feels like a workaround...
Jeff Thompson
From what I can tell, Steel Shapes are not labeled and listed as the same part in Archicad 27.  They've been given new names and the tool has been modified.
Archicad Legacy Objects USA.lcf/Object Library/00 General/Detailer Library/Steel Shapes...  (for W Column and W Beam)
Archicad Legacy Objects USA.lcf/Object Library/00 General/Detailer Library/Wood/Wood Frame... (for DET_Stud)
Archicad Legacy Objects USA.lcf/Object Library/00 General/Detailer Library/Masonry Units/Blocks Common... (for CMU)
Hope this helps.
Project Manager
Oosh
Hi Jeff,
Really appreciate you sending such a clear and thorough response.
Unfortunately, the TS Column 27 and W Beams 27 are 3D objects, not from the DET library. Not sure where they could've gone or what they've been re-named as in AC28.
Thanks again!
Eduardo Rolon
Mine has it. Are you sure that you have loaded the latest "Archicad Library 28" I think they were not available in the one from Tech Preview?
AC29 US/INT -> AC08
another Moderator
David Maudlin
  • W Column
  • W Beam
The W Column 27 is also a 3D Object. The closest equivalent I could find in the 28 Library is the Universal Beams Column (Object Library > 05 Metals > 05 50 00 Metal Fabrications > Steel Column BS), but it is using the BS Standard, not the W Shapes used in the US, so not of much use here.
