Durval
Why can't I change dimension of hood's connections
What should I do to unlock dimensions for connections in the Hood 17 object?
[/img]
--- www.dtabach.com.br ---
AC 28/29 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sequoia
3 Replies 3
Erwin Edel
For what it is worth, I don't have these option available at all. Not in the Dutch library or from the part on BIMcomponents https://bimcomponents.com/GSM/Details/16108
Maybe it is something from a MEP addon?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Durval
Exactly, Erwin, it's an option that becomes available when MEP Add-On is enabled. Some objects like this hood (washing machines, dryers etc) change from an 'object' to an 'equipment' and offer aditional parameters.
I tried to change dimensions of ducts possibly related to the hood, but did not get to change the hood connection.
David Maudlin
Durval:
I took a brief look at the Parameter Script, and it looks like the connection size is based on the hood type, and in some cases (such as the hood type in your screen shot) those dimensions are fixed and locked. If you cannot use another hood type, then you could try editing the Scripts.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
