Why is reveal to wall face not available on D2 sliding 17?
This is ridiculous! Several things about this door are just plain going backwards. I can't get the sliding glass door panel frame to read correctly in plan. the leaf pane stile is shown as about 4" wide even though the dialog box controlling its width is set at 2" - someone on the forum was able to change this to read correctly in plan view, but they had to change the GDL script settings.
Why is the reveal to wall face not available anymore when doing a sliding glass door? this has always been available in previous versions!!
WTF Graphisoft?
NCornia
Graphisoft Alumni
Graphisoft Alumni
Jonathan,
I took a look at the D2 Siding 17 door and was not able to replicate an issue similar to yours. Please tell with more detail, or show with a screenshot, specifically what settings are not affecting the display of the door as you would expect. Then I have a better idea of what to look for.
As for the reveal, check the wall closure settings for that door and change the option from what it is currently set to. HelpCenter: Wall Closure
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
