‎2016-05-02
10:52 AM
‎2023-05-24
12:30 PM
Rubia Torres
‎2016-05-02 12:47 PM
‎2016-05-02 09:27 PM
[/img]
‎2016-06-09 02:24 AM
‎2016-06-09 03:01 AM
‎2016-06-24 10:20 PM
‎2016-06-25 02:28 AM
‎2020-04-25 03:43 AM
LaszloNagy wrote:Lazlo--I'm pulling my hair out working through this. The settings done in this manner do not stick--at all. Either there is more to the story or there is missing info.
To create, for example, a new Window Marker:
1. Activate the Window\Toolbars\Edit GDL Library Parts menu command.
2. Click the Open Object by Subtype button.
3. In the appearing Dialog, to the following level of the hierarchy:
General GDL Object\Documentation Element\Drawing Symbol\Marker\Window-Door-Skylight Marker\Window Marker\
and select one of the available Markers, then click the Open button.
4. Activate the File\Save As menu command and save it under a new name, either into on of your linked libraries or into the Embedded Library.
5. Make your modifications to it.
6. The marker should be available in the Marker drop-down list of the Dimension panel of the Window Settings Dialog.
‎2020-04-25 04:05 PM
‎2020-04-26
10:59 PM
‎2024-02-18
05:08 PM
Lazlo,
I've saved the marker and it's always available to choose. The problem is that the marker size is never correct (always 73.7 instead of 26 pt) nor is the pen used (always 1 instead of 3). Every other custom setting is correct--font, font size and width, marker shape, positions, offsets, etc. Even overrides. See images.
