Window and door layers?
I have compleated a couple sets of drawings in AC so far. I must have missed or forgotten something because all of the sudden I can't figure out how windows and doors layers work. Do windows and doors automaticly have there own layers? I cant find any whare to define the layer of these objects. thanks
7 REPLIES 7
Aussie John
Mark - windows and door become part of the wall and as such take on the layer of the wall.
And exception is in plotmaker which for some unknown reason creates a layer for the door/window.
Cheers John
[/size]
I have compleated a couple sets of drawings in AC so far. I must have missed or forgotten something because all of the sudden I can't figure out how window and door layers work. Do windows and doors automaticly have there own layers? I cant find any whare to define the layer of these objects. thanks
Sorry! I don't know how but my question was posted 3 times, oops!
Eduardo Rolon
check on display options to specify how doors and windows are shoen
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Link
They don't really have layers mate - they simply become part of the wall they are inserted into. Same as the Wall End tool.
Link.
That makes alot of sense. Explains why I diddn't remember creating door and window layers. Thanks!
Djordje
You can when saving to DWG. PlotMaker also does it.
If you want to control the visibility and representation, a combination of the Display options and window/doors parameters usually does the trick.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
