‎2004-07-10
12:15 AM
‎2023-05-26
11:46 AM
Rubia Torres
‎2004-07-11 08:15 PM
Miki wrote:You already do. It is called relative coordinate input.
I wish to have option to insert window/door in specified (side or center) distance from the corner of the wall. I see it like that:
I select window/door tool -> select center or side anchor point -> select direct or distance insertion style -> pick wall on near corner or near corner (if this is near window/door then window/door active point -with possibility to select which one - is used as reference point) input distance -> ENTER.
Voila.
‎2004-07-12 01:07 AM
‎2004-07-12 02:03 AM
Miki wrote:There are many ways to accomplish what you want to do which are very direct and easy to do. Such as placing the user origin (then type "r" and the distance), and different settings for placement by divisions, distance and percentage from endpoints or nearest intersection.
I it "almost" like what I want. I was playing around with that tool, but it is not comfortable in use, and it takes distance from start point of the wall not the current corner/point so when I want to insert window/door on other side it is useless. There is also no shortcut (or I don't know it) also.
‎2004-07-12 07:23 PM
Miki wrote:No need to move the origin; if the distance is horizontal or vertical, use Xvalue+, Yvalue+ (or -); if the distance from the reference point is at the angle, the fastest way is to set the division value to your distance.
‎2004-07-12 11:47 PM
