Woman in the Red Dress
Does anyone still have this object? will she work in AC16?, can we change the color of her dress to White?
Does anyone have a Bride? Designing a Bridal Shop and need mannequins with Bride Dresses on them...all I have is Dress 2.
10 REPLIES 10
David Collins
Kate, the Woman in Red Dress, has aged along with the rest of us, but what she lacks in polygons she still makes up for in style. I found her and her Goth sister Vicki in the old "People and More" library from ArchiCAD 6.5. Vicki might be persuaded to wear a white dress for a day or two if you make her the right offer.
Unfortunately they both came into ArchiCAD 16 with lots of error messages and no feet. I converted them to into morphs, added some shoes and loaded them both into a single object file with parameters for positions (standing, walking, leaning) and materials.
Look for "Woman in Red" in Bim Components.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
THANK YOU SO MUCH!
šŸ˜„
rocorona
To get rid of the errors, open the object, go to the 3D script and use the Find&Replace command, from the Edit menu.
Search: .e
Replace: e
Save&enjoy
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
David Maudlin
Search: .e
Replace: e
When I open the library part, the entire 3D Script is:
if treed=0 then end
MULX	A/0.460000
MULY	B/0.706308
MULZ	zzyzx/1.7
Binary 1
DEL top
So this fix is not available in the US version.
When viewing the object I got the same error messages in AC16 as David Collins, but worked properly when viewed in AC 7.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
rocorona
I was referring to the object from BIMcomponents, loaded by David Collins. Downloading it, I get a very long script, where some numbers are in a erroneous "exponential" format, that is probably supported in older versions. Here an example:
1.55e3 = 1550
1.05e3 = 1050
1.00e3 = 1000 (correct, it can also be 1e3)
1.e3 = 1000 (is the same of the previous, but a decimal point without digits after it is reported as an error)
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
David Collins
rocorona wrote:
I was referring to the object from BIMcomponents... where some numbers are in a erroneous "exponential" format...)
This is very strange. The new script was generated entirely by ArchiCAD 16.
I can find instances of both the ".e" and the "e" exponential notation in the 3d script, but no error messages here.
vert 0.0401, -5.e-5, 1.54412 ! #239
vert -1.73472e-18, 0.0771071, 0.999941 ! #240
investigating....
David Collins
Great to see old objects come to life with the help of the Morph Tool.
David, you might also experiment with the Curve & Merge Edges and the Smooth & Merge Faces commands of the Morph Tool to create a less blocky appearance.
David Collins
laszlonagy wrote:
David, you might also experiment with the Curve & Merge Edges...
This did occur to me, but I didn't want to spoil her classical retro style. Besides, a girl's gotta watch her polygons...
David Collins
