‎2012-10-31 01:01 AM
‎2012-11-07 06:32 PM
‎2012-11-07 06:39 PM
David wrote:😄
Kate, the Woman in Red Dress, has aged along with the rest of us, but what she lacks in polygons she still makes up for in style. I found her and her Goth sister Vicki in the old "People and More" library from ArchiCAD 6.5. Vicki might be persuaded to wear a white dress for a day or two if you make her the right offer.
Unfortunately they both came into ArchiCAD 16 with lots of error messages and no feet. I converted them to into morphs, added some shoes and loaded them both into a single object file with parameters for positions (standing, walking, leaning) and materials.
Look for "Woman in Red" in Bim Components.
‎2012-11-07 08:04 PM
‎2012-11-08 01:50 PM
rocorona wrote:When I open the library part, the entire 3D Script is:
To get rid of the errors, open the object, go to the 3D script and use the Find&Replace command, from the Edit menu.
Search: .e
Replace: e
if treed=0 then end MULX A/0.460000 MULY B/0.706308 MULZ zzyzx/1.7 Binary 1 DEL topSo this fix is not available in the US version.
‎2012-11-08 02:04 PM
‎2012-11-09 07:43 AM
rocorona wrote:
I was referring to the object from BIMcomponents... where some numbers are in a erroneous "exponential" format...)
‎2012-11-09 03:47 PM
‎2012-11-10 12:53 PM
laszlonagy wrote:
David, you might also experiment with the Curve & Merge Edges...
‎2012-11-10 01:03 PM
