We value your input!
Working with a mesh
Johann_P
I used a morph to create a parking platform that follows the existing topography.
I now need to rotate a portion of the parking layout by a degree or 2.
What would be the best way?
I only need to rotate the portion shown in yellow.
I cant seem to multi-select all the nodes I need.
If I use the axe to chop it loose from the rest, it cuts more than what is needed.
Can I set the axe to only chop where I draw the line, and not through the entire object?
Any advice?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Podolsky
Ace
You can actually cut it, how you did. And after connect parts, that originally needs to be connected, with a command: Design / Modify Morph / Union
I think this is the fastest way.
6 REPLIES 6
Podolsky
Ace
Lingwisyer
Guru
Use Trim between two nodes at your junction instead of Split?
Ling.
Johann_P
Thanks Podolsky,
I think your method works best.
I have to make 2 more cuts with the axe, to isolate the specific portion and then join them all with the Morph Union tool
Windows 10 Pro
I don't think there is a need for the extra cuts.
Just make the first cut and then union parts 1, 2 & 3 back together.
Or wait until you adjust part 4 and then union them all together.
Lingwisyer
Guru
Split creates a single morph out of each side even parts are not connected.
Was sure I was using trim yesterday, but now it does not work...
Of course - long time since I have done this (if at all?).
Yes, you will need the extra splits then - sorry for the wrong info.
