2010-02-11 07:56 PM
2010-02-15 09:26 PM
Krippahl wrote:Unfortunately we can't change string parameters with hotspots (until Matthew's "hottext"
Hello Braza
That would be a powerful object:
A Stamp that would allow data input in the plan window.
You think that is possible?
2010-02-16 12:15 AM
Krippahl wrote:There are ways to do this through the API, but would probably not be far off the 10 hours it would take you to enter the text the hard way
2010-02-16 11:16 AM
Braza wrote:I can not understand all the implications of this method.
But as you just need to insert a simple pre-defined code... I was thinking of usingthistechnic. Here we use an integer parameter to control another string parameter values... Does it gives what you want?
2010-02-16 04:09 PM
2010-02-16 04:30 PM
2010-02-18 11:40 AM
