Podolsky wrote:
it cannot read property defined in the wall.
Not even with ... n = REQUEST ("Properties_Of_Parent", propertyType, parentProperties)
Podolsky wrote:
That means you need to set fire-rated value for the symbol itself (and separately for the wall).That is already sucks - it terms of automation of the workflow.
That is why I suggested that the fore rating may be built into the wall name or ID.
The rating could be searched for and the correct line type set.
Podolsky wrote:
Also with wall accessory you cannot select all walls at one and with one click place wall accessories there - you need to go through each wall and - click-click-click...
Of course you can select more than one wall.
With the accessory you traditionally choose which side of the wall you want the accessory on.
In this case it doesn't matter, as no matter which side you choose, you want the line to offset half the width of the wall.
Podolsky wrote:
And at the end - wall accessory is optional function of ArchiCAD - with additional download. If some user don't have it - he must download, close ArchiCAD, install and open ArchiCAD again.
True, but you only have to do it once and you then have the benefit of all the accessory add-ons.
Podolsky wrote:
Have you tried the label I uploaded? Script is short, use of it is very simple and it really works and gives exactly what needed.
Just had a quick look at it.
Obviously you have to set up the properties and the line types if you don't have those.
And you have to force a re-build if you modify the wall?
Other labels (text) update automatically.
I guess it is something to do with using the geometry of the wall?
An interesting use of a label.
I have no idea if my suggestion of the accessory works or not as I haven't tried it.
Just trying to throw some ideas out there.
