‎2008-08-11 01:48 AM
‎2008-08-11 03:00 AM
Jeff wrote:is the object itself set to show on the storey above? you set up 'storey sensitivity' in the stair object's parameters, but you still have to switch on the display of that object on the floor above . . .
I can't make the upper section above the stair break invisible. I tried changing it in both the selection settings and the open object settings. Both did nothing.
‎2008-08-11 03:28 AM
‎2008-08-11 04:54 AM
another Moderator
another Moderator
‎2008-08-11 06:31 AM
‎2008-08-11 02:29 PM
another Moderator
‎2008-08-12 12:47 AM
‎2008-08-12 04:14 AM
