archicad doors problem
Hello everyone, I'm having a problem with ArchiCAD 22, when I try to add doors and try to change the leaf doors, I always get a door with wood override material, when I go to settings, the override material is unchecked.
I really need help with this.
I cannot reproduce this with the USA library. I'm guessing you are using AC 22 INT and the INT library? Please let us know.
Will leave this post in the Working in ARCHICAD forum for now... although it appears to be a Library issue...
Can anyone with INT reproduce the reported issue?
Thanks,
One of the forum moderators
Thanks,
Yes it is a INT version
Lingwisyer
Guru
Check your MVO. Mine (AUS) was set to 3D Simplified as default...
Ling.
