2007-03-12 11:53 AM
2007-03-12 09:07 PM
IF STRSTR(AC_DrawingScale, "1:1") > 0 THEN...This tests to see if the substring "1:1" is contained within the returned value.
2007-03-13 08:56 AM
2007-03-13 03:19 PM
2007-03-15 08:32 AM
2007-03-15 11:19 AM
So is it impossible to get values outYes: Impossible.
from <DRAWINGSCALE>
2007-03-15 03:50 PM
cejava1 wrote:I just looked closer and realized that you are using the autotext <DRAWINGSCALE> and not the parameter name DrawingScale (without the carets).
from <DRAWINGSCALE> ??
2007-03-29 09:56 AM
2007-03-29 12:58 PM
!»» Example with automatic scale string of drawing stamps scaleS=AC_DrawingScale !»» CONVERT SCALE-STRING TO NUMERIC scaleN=0 !»» Cut of "M" at the beginning. Not needed. s=STRSTR(scaleS,"M") IF s THEN scaleS=STRSUB(scaleS,s+1,STRLEN(scaleS)-s) !»» Imperial or metric? s=STRSTR(scaleS,"=") !»» Converting ... IF s THEN !»» Scale notation is imperial sts=SPLIT(STRSUB(scaleS,1,s-1),"%n",lengthR) sts=SPLIT(STRSUB(scaleS,s+1,STRLEN(scaleS)-s),"%n",lengthP) IF lengthR THEN scaleN=lengthP/lengthR ELSE scaleN=MAX(lengthP,0) ELSE !»» Scale notation is metric IF NOT(scaleS="auto") THEN s=STRSTR((scaleS,":") IF s THEN sts=SPLIT(STRSUB(scaleS,1,s-1),"%n",lengthR) sts=SPLIT(STRSUB(scaleS,s+1,STRLEN(scaleS)-s),"%n",lengthP) IF lengthR THEN scaleN=lengthP/lengthR ELSE scaleN=MAX(lengthP,0) ELSE sts=SPLIT(scaleS,"%n",scaleN) ENDIF ENDIF ENDIF !»» scaleN contains the divisor of the scale. !»» CONVERT NUMERIC TO IMPERIAL NOTATION IF scaleN<2000 AND NOT(scaleN>=100 AND FRA(scaleN/10)<0.001 ) THEN scaleI=STR("%^.128fi",1" * 12/scaleN)+´=1'0"´ ELSE scaleI=´1"=´+STR("%^.32ffi",scaleN*1") ENDIF !»» scaleI contains the imperial scale string. !»» CONVERT NUMERIC TO METRIC NOTATION praefix="M " IF scaleN<1 THEN scaleM=praefix+STR("%^.0m",1/scaleN)+":1" ELSE scaleM=praefix+"1:"+STR("%^.0m",scaleN) ENDIF !»» scaleM contains the metric scale string. !»» PRINT RESULTS txt="»»"+scaleS+"««" txt=txt+" »»"+STR("%.3",scaleN)+"««" txt=txt+" »»"+scaleI+"««" txt=txt+" »»"+scaleM+"««" TEXT2 0,0,txt END
2007-03-29 02:11 PM
