ā2024-01-31
06:35 PM
ā2024-02-06
12:25 AM
The lower and upper cabinets in 26 are not square. The upper right corners are on top of each other. They are the same width and same orientation. The lower right corner is slightly off. It is not very noticeable, but with a large kitchen it adds up and becomes noticeable.
āā
ā2024-02-01 02:14 AM
The problem is not very obvious in your images.
What cabinet objects are you using?
How are you arranging them - can you show them in 3D so we can see what you are trying to do?
Can you mark up where the problem is?
We have to try to replicate your problem, so we need to know exactly what you are trying to do.
ā2024-02-03 07:57 PM
I got them to line up. I had to type in a o degree rotation and then type in a 270 degree rotation again.
It is out of the box base cabinet and upper cabinet.
