‎2011-11-24
07:24 PM
‎2023-05-24
11:50 AM
Rubia Torres
‎2011-11-24 11:36 PM
‎2016-07-20 07:04 PM
‎2016-07-20 11:41 PM
‎2016-07-21 12:31 AM
‎2016-07-22 01:25 PM
‎2016-12-29 04:50 PM
‎2016-12-30 12:55 AM
‎2016-12-31 05:03 PM
ritadiniz wrote:The Skylight will always cut a rectangle form into the Roof. You need to script your Skylight library part so that it also contains a body that fills the gap between the rectangular hole and the Skylight shape.
any update on this post. I need to make a custom skylight. I did an object with subtype skylight, but my form is not a rectangle and the roof hole that appears is a rectangle form.
‎2017-01-02 05:48 PM
laszlonagy wrote:Sorry, but could you tell me how can i do that? or where can i find it...thank you so muchritadiniz wrote:The Skylight will always cut a rectangle form into the Roof. You need to script your Skylight library part so that it also contains a body that fills the gap between the rectangular hole and the Skylight shape.
