diferent handle in door
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-01-30
12:13 PM
2025-01-30
05:44 PM
Hi, it is posible to place a diferent handle in a fire protection door? the bar in one face of the door and other type of handle in the other face of the same door?
Operating system used: Mac Intel-based sonoma
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-01-30 12:37 PM
If you are using Archciad 28, load DACH or USA library which have this possibility available.
MacBook Pro M1 Max
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-01-30 08:28 PM
hi karel, is therre a way to use it in archicad 26?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-01-31 02:16 AM
You would have to download and install the DACH or USA version of the program.
Be careful to install in a different folder than your current Archicad.
Then you will have access to the libraries which you can load - beware though there may be conflicts with your current library.
Once you have copied out the libraries, you can uninstall the other program.
Or if you search in BIMComponents, you may be able to find the DACH/USA version of just the door you want rather than having to install the entire library.
