door leaf not changing
Dave Brach
no matter what leaf I choose for this door it will only show a flat panel
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
Erwin Edel
Check the model view options. There is most likely a setting that shows doors as 'simplified' turned on.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Dave Brach
THANK YOU. that was it
