gdl objects Help
I have a gdl library collection ( mostly archibase) .
I am adding them in archicad via library manager each time i want to use them.
Is there any way to make them ''lighter'' ?
When i use more than 5-10 objects the pln , is very have.( No money for upgrade) ..
2 Replies 2
Djordje
The only way is not to use the converted 3ds/dxf/dwg objects, which most of the objects on the archibase web site are ...
Did you check ALL the free pure GDL resources?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
Dekanat:
If you want to spend the time to edit each object, take a look at this thread:
2D symbol of Archibase.net objects
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
