help required 2d symbol in gsm
I am trying to create the New vent Window in ArchiCAD using Gsm Script. I had created the all frames and louver blades in 3D Script.
In 2D script at present i am using the 3D Projection concept. In this case I am getting all the 3D objects projection in top view with hide mode its fine. When I fix the scale factor on floor plan the same projection are coming in all the scale factor.
Is there any other method I need implement for scale factor. In the existing library window creation they called "GS corner window function" or "Basic window function" as a Macro. But i cant find out the "GS corner window function.gsm". Kindly assist me to get the 2D symbolic view with scale factor concept.
Thanks & Regards,
Asvini.V
1 Reply 1
If you want different looking projections in 2D at different scales then you will need to script the 2D as well.
You can use the Project2 for scales (GLOB_SCALE) less than a certain level and then for the others scales you can script individual lines and rectangles for the frames.
