2011-09-27
04:42 PM
2023-05-24
10:15 AM
Rubia Torres
2011-09-28 10:29 AM
"pixpast" wrote:
just something i learned.
i created a full 3d german fire truck using slabs on plan.
tried to save it as object, but it kept arriving in my project as lieing on its side.
so i saved it as a door.
then in my real project, i created a wall and then inserted my door.
the fire truck stood up perfect.
but of course i had a big wall in the middle of my project.
so i brough the wall right back to the front and back of my fire truck, then the truck was there and no sign of a wall.
there must be a easier way of creating an object from plan and then flipping it up 90 degrees.
any help guys ?
2011-09-28 10:39 AM
pixpast wrote:Eduardo mentioned the trick earlier in this thread.
2011-09-28 10:57 AM
2011-09-28 11:33 AM
In the 3D widow you need to set the projection to the view you would like to see in plan.
So you will need a side view with a camera azimuth of 90°.
In 3D it will appear as if you are looking at the top of your fire truck.
Now you save this as a 3D object.
It is no use just rotating the 3D view - you must set the projection settings.
2011-09-28 02:34 PM
2011-09-28 02:45 PM
2011-09-28 02:51 PM
2011-09-28 03:34 PM
2011-09-28 04:00 PM
2011-09-28 04:25 PM
