is there an object like this?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-12-04
12:05 PM
2023-05-24
11:34 AM
Rubia Torres
2017-12-04
12:05 PM
Looking for a window with horisontal post between clear glass and blind. I can't find any other way to this rather than a custom window panel for the blind and a piece of wall behind the blind. If all of this exists somewhere in one object I'm interested to know
Mats
AC 25 SWE Full
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-04 01:28 PM
2017-12-04
01:28 PM
I'd start with the vertical Multi-Sash Window and go from there. You may be able to adjust Sash 1 (bottom sash) to get you there or most of the way there.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Rhino 8 Mac
MacOS 15.2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-04 04:42 PM
2017-12-04
04:42 PM
Aaron wrote:I tried som different ones and figure it's easiest with a regular window and custom panel at the bottom. However the wall part behind the blind hs to be a separate wall I guess.
AC 25 SWE Full
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-05 01:54 AM
2017-12-05
01:54 AM
Any window you place will cut a hole through the entire wall.
Unless you want to get into the script and start playing around with the WALLNICHE command (rather than WALLHOLE) as this will allow you to set the depth of the cut.
The easiest way if you are not happy playing with the GDL is to add a separate bit of wall back in.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-05 10:32 AM
2017-12-05
10:32 AM
You might be able to get close by setting up a custom jamb on the inside.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
