Mats_Knutsson
Mentor
is there an object like this?
Looking for a window with horisontal post between clear glass and blind. I can't find any other way to this rather than a custom window panel for the blind and a piece of wall behind the blind. If all of this exists somewhere in one object I'm interested to know
Mats
AC 25 SWE Full
4 Replies 4
Aaron Bourgoin
I'd start with the vertical Multi-Sash Window and go from there. You may be able to adjust Sash 1 (bottom sash) to get you there or most of the way there.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Mats_Knutsson
Mentor
I tried som different ones and figure it's easiest with a regular window and custom panel at the bottom. However the wall part behind the blind hs to be a separate wall I guess.
AC 25 SWE Full
Any window you place will cut a hole through the entire wall.
Unless you want to get into the script and start playing around with the WALLNICHE command (rather than WALLHOLE) as this will allow you to set the depth of the cut.
The easiest way if you are not happy playing with the GDL is to add a separate bit of wall back in.
Erwin Edel
You might be able to get close by setting up a custom jamb on the inside.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
