list of placed objects on a layout
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2014-10-08 10:42 AM
Any idea?
Has somebody ever tried to get it?
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 11:39 AM
Any particular object category you are thinking off here (eletrical, furniture, etc)?
Or are you referring to revised objects only?
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 11:50 AM
I saw something similar in the keynote by cadimage.
They have a schedule that can show only the labels on that specific layout.
Win 10 Pro 64bit
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 12:23 PM
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 01:28 PM
What you suggest It's not exactly what I'm trying to achieve.
I'm trying to have a list of only those objects visible on a certain layout. Of course in the layout I can place details, floor plans, sections, worksheet ...
Win 10 Pro 64bit
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 04:56 PM
Well, it "can" be done using GDL, but is not an easy task. The thing is: what kind of objects are you trying to schedule and how do you want them scheduled? I ask because views (per your last comment) can be scheduled. Objects however, cannot be AFAIK.
Please read this thread:
If you like, I can upload the test I did using the code posted (with some modifications), so you can see how it works.
Best regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 05:47 PM
The schedule has to be placed in the masterlayout and it will be produced by GDL also.
My problem is how to know which objects are visible in that specific layout.
Win 10 Pro 64bit
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 07:49 PM
I read the code you mentioned in the linked topic.
... I need to study the "request" command for Homedbinfo ...
What I understood is that I have to write in a file the "context" (and the other data I need to schedule) where "myobject "is placed (plan, section, detail, layout), then place the "scheduler" in the masterlayout; the scheduler will read the file written by "myobjects" and check if the "context" (for each myobject) is present on that specific layout ...
A little bit complicated ...
I will try
Win 10 Pro 64bit
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 08:21 PM
In that context, you have one object that writes information to a text file, and then a scheduler object that sorts through it to find the objects that are placed in that layout only. Just not sure you can create an object that you could place on a master layout and behave differently on each layout...
But what I understand you are trying to do is far more complex, so please correct me if I'm wrong: you want to place objects in standard views (plan, sections, details, etc), then place those views in layouts and create a schedule object that will know what views are placed in each layout and if they contain the objects you want to schedule? If that is what you are after, I don't think GDL can go that far. Something like this would need to be programmed using the API, and is way more advanced.
There might be some other workarounds, or maybe a different way to show what you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-08 08:48 PM
sinceV6 wrote:What you understood is correct.
Well... not quite. The code in the example only works if both objects are placed directly in a layout, not a master. Didn't try to make it work that way though, in the couple hour test I made.
I'm making some simple beginning tests. I will keep the thread updated.
I'm starting from this point
Win 10 Pro 64bit
www.almadw.it
