rob2218
missing BIM server libraries?
what does this mean and how do I fix it?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
3 Replies 3
Eduardo Rolon
You have to load the migration libraries located in the "Graphisoft -> Archicad 14 -> Archicad Migration Libraries".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
rob2218
We have done the migration loading on the individual MAC stations but do I need to load some libraries on the BIM Server as well?
or what do I need to do?
This is a teamwork file we are working on as well as individual PLN's which compose the teamwork database.
thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob,
Look through this post.
There are some issues loading BIM Server Libraries in v14. It has to do with the way you connect to the BIM Server (bonjour, IP, DNS, etc.) I had to go back to using bonjour to avoid the "Offline" or "Not Available" messages.
Also, I have all libraries loaded on the BIM Server. I DO NOT use Linked Libraries at all, even solo projects.
