2010-08-05 02:47 PM
2010-08-05 03:01 PM
2010-08-13 09:49 PM
2010-08-14 02:13 AM
2010-08-14 03:30 PM
Erika wrote:Be careful to use the syringe tool in the dialog or all the parts will lose any differentiated parameter settings.
It is reading their old library name. You will need to repoint each object to the new library part.
Using Find & Select, select all of object A and then navigate to the new/revised library part. Do the same for the rest of the objects.
2010-08-14 09:37 PM
2010-08-26 01:17 AM
2010-08-26 01:20 AM
2010-09-16 09:03 AM
2011-01-31 06:59 AM
Master wrote:I think I'm in the same boat too, created GSM library parts, changed the 3D and create a new (changed) GSM part over the top of the previous one.
Using 'save as' when saving an object, the unique identification number (GUID) is changed. Since AC 13 looks for the GUID but cannot find it, even when the name is the same . So a dot shown.
Strangely the error is not found in your current session of AC but only when AC is restarted. So in your current session is the best moment to use Find and Select and select all the objects. Then you have to 'refresh' the GUID by using 'next library part' and 'previous library part'.
tip: in AC13 always use versionnumbers for your objects.
