MuriloNoleto
problem whit loading custom library
Hello everybody.
I'm have a problem with loading the ArchiCAD's default object library, I can't load the doors, windows and some objects, in addition, the archicad accuses a problem in the 2D representation of those elements.
I reinstalled twice and the problem persists. I've tried to incorporate the .lcf via manager library and did not resolve. I extract the container and nothing.
I had the same version of ArchiCAD on the same computer (isn't what is described in the signature), there was a "bug" strange and I need to reinstall.
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 29 | Win 11 |
5 Replies 5
Erika Epstein
By any chance are you forgetting that doors and windows are accessed via their own tools not the (library) Object tool?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It the problem is not what Erika suggested, then please show us some screenshots of the problem.
MuriloNoleto
No way...kkkk
Here are the links of the images (my archicad is a portuguese version)
http://img694.imageshack.us/img694/2082/figura1lf.jpg
http://img130.imageshack.us/img130/7345/figura2js.jpg
http://img341.imageshack.us/img341/2070/figura3w.jpg
http://img704.imageshack.us/img704/9362/figura4i.jpg
Thanks.
Murilo Noleto
It looks like none of the library parts are loaded properly, but the library manager hasn't noticed! Have a look to see whether the Archicad Library13.lcf actually exists. It should be around 75mb or so.
Before re-installing, did you properly un-install the program when you had the problem before? Are you running the latest library update?
It's an obvious question, but have you tried re-starting the machine?
MuriloNoleto
I solved the problem folks.
I replaced the problematic .lcf file on this computer for other, located on another computer that was OK. Functioned normally.
Thanks. (My english is not good)
Murilo Noleto
