2008-03-14
08:18 AM
2023-05-24
12:43 PM
Rubia Torres
2008-03-16 01:51 AM
Vic wrote:The result.
Or if you have the time - test it on your own?/..
2008-03-16 02:47 AM
2008-03-16 12:45 PM
2008-03-17 12:12 AM
Vic wrote:Vic, see attached for the settings I have to achieve what you want.
- when I put the window on a wall, on the plan I have no lines between the wall and the window's frame - is there a way to have lines the same type as the outline lines of the wall? /......
2008-03-17 07:54 AM
2008-03-17 09:04 AM
Vic wrote:You should be using 8.1, if you have that library.
/....I tried to use it loading the whole ArchiCAD 8 library in ArchiCAD 11.
Vic wrote:Open each of the library parts.
What was interesting was the fact that loading it this way it does display the 'wall contours' selection in the parameters section.
Vic wrote:Shouldn't make any difference. I am regularly dealing with the "Dark Side" without any overt difficulty.
Maybe this setting is OS specific and can not be used across systems?
Vic wrote:Line 2 is commented out in the master script, so should not show.
Since you said the GDL script for version 8 was not as complicated as for 11 - maybe you could make out something of the error messages it gives me when I load that same window from my ArchiCAD 8 library?
Vic wrote:This should not be the case, and cannot work it out as everything works smoothly at my end.
Dropdown selection menus in the parameters still turned into input boxes... I guess libraries on Windows don't mix versions as smoothly or need extra modifications.
2008-03-17 09:28 AM
2008-03-17 11:32 AM
Can't find Macro:trimmyboy, called at line 140 in the 2D script of the file W Emergency Escape.gsm
2008-03-17 12:39 PM
Vic wrote:Glad to assist in a great work around, Vic.
And voila! Now I have the wall contours selection AND drop down menus in the parameters window of that second window!![]()
Anyway - I have no problem using that 'latest settings' option on every new project so again - thank you very much for your help
As for the last library you attached - it gives the following error:Can't find Macro:trimmyboy, called at line 140 in the 2D script of the file W Emergency Escape.gsm
2008-03-17 01:21 PM
