resizing an embedded object
Hello.
I downloaded and embedded an object. I am trying to resize it, but it wouldn't work. It shows the diminished dimensions in the info box, but in plan the object is the same.
What can I do?
Thank you.
13 REPLIES 13
David Maudlin
igreere:
The Object was probably scripted to be a single size. You can get around this by saving it as a new Object (File > Libraries and Objects > Save Selection as... > Object... command), which will add code to allow overall size changes in the X, Y and Z directions.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for the answer. I tried this way, but did not work.
Eduardo Rolon
Option to try is to convert the Object to Morph -> rescale the Morph -> and save as Object again if necessary.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Archicad doesn't let me scale the morph...
Eduardo Rolon
Edit-> Reshape ->Resize
is not working for you?
AC28 US/INT -> AC08
another Moderator
unfortunately not
Eduardo Rolon
What error is it giving if any? If none then it looks like you will need to re-install AC because that is not normal.
Just to be sure, the steps are:
1. Select Object
2. Right Click on object and select convert to morph
3. Select Object
4. Edit-> Reshape-> Resize
5. Select either Graphically or unselect it so that you can use a %
6. If graphically then click to establish the base point, then click to define the existing dimension, then click to choose the final size.
7. If by percentage then write the % and then click to apply.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Step 4
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Step 5
AC28 US/INT -> AC08
another Moderator
