sliding door D1 Pocket
I tried unsuccessfully to change the fill ( in 2D)of the sliding door D1 Pocket of the AC Library. Usually its easy to change the fills/colors of an door, objects etc. in settings/parameter/ 2D Representation. But at this door its not possible. How can I change it ?
Jens
1 Reply 1
Jens - I believe that there is currently no way to fix this fill on standard parts - I had hoped that this condition would be fixed with an update - but no luck so far. The usual way is to edit the GDL code of the door leaf, removing the fill. I searched and could not find where the offending fill was written.
I know this doesn't help - perhaps someone smarter than I could figure it out.
Lew Bishop
AC9/ P4-2.53 nVidea 440 XPPro
