solar panels / texture anyone?
Anyone got a solar panel object or photovaltaic texture that they would like to share?
Thanks in advance
8 REPLIES 8
Laura Yanoviak
Not a texture, but ACE has a nice photovoltaic material:
ArchiCAD East
Andy Thomson
Good point, we do a lot of these now. I will find/make a good shader with image file/texture, as a PNG file. Typically the material has been enough, but it would be nice to get the alpha effect/shadows from the panels without the white backing, I like those kind, but they are becoming scarce, the white backing seems to be gaining popularity in manufacturing circles.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
to answer my own question! yes there is now a library part in the AC12 library - do a search for solar. The texture applied is pretty poor though.
Here is a texture attached if anyone want it.
Djordje
Could you place it in the Depository?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thank you for texture, Lennox!
And there is the right place and time to ask - does anyone have a solar pannel library part? šŸ˜‰
Rod Jurich
kliment wrote:
/....k - does anyone have a solar pannel library part? šŸ˜‰
Kliment, you are welcome to use my HWS. I've modified to turn the tank off.
Rename, use as you see fit. Version 11.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Thank you, Rod!
Brett Brown
There is also a free one and many other objects at www.archicadselect.com.
Just sign up and any objects over 6 months old you can download free
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
