I've created a downlight library part that I want to recess in the ceiling slab using solid element operations (SEO) subtraction w/ downward extrusion. Solid element operations will not work (or sometimes works at first then disappears later) while the object subtype is "Light", but it works perfect when the object subtype is set to "Geometric Shape." This is a huge problem...
I'm trying to see if I can "call" via a subroutine the "Geometric Shape" object into a "Light" object.
Is this problem documented anywhere?
This really screws up my lighting schedules if my downlight has to be an "object" vs. a "light."
Scott
ArchiCAD 29, Windows 11
