story setting head target - where do I change the graphics?
rob2218
where is the setting parameters where I can change the "look" (graphics) of the target head in the story settings?
is it in the sections markers?
is it in the story settings themselves??? where?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
17 REPLIES 17
Try:
Object Depository
01 General
Elevation Dimensions Marker
Author: BeArt
Style 3 within object for "upside down" triangle
May be compatible with 18.
Erwin Edel
That's why we use the elevation dimensions here
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
rob2218
it's not there.
formworksdesign wrote:
Try:
Object Depository
01 General
Author: BeArt
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
https://bimcomponents.com/GSM/Details/8303 probably this one.
www.leloup.nl
Depository > 01 General > Graphic Symbols
Scroll down to the 12th object.
rob2218
ok, man...do I need some basics here...ok I found the object but it's an LCF file in a winzip file.
I've extracted the LCF to a folder in my PC...now what?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
guys (GS)...really, this shouldnt be that complicated just cause an architect wants to use a different elevation marker head height tag object.....it should simply be "PICK ONE" or draw something in 2D and save it as a marker head....or something to that effect.
Sheesh.....was this worked on the by the "stair programmer department"?
(frustrated here).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Robb:
Read here:
helpcenter.graphisoft.com/tips/how-to-extract-library-parts-from-the-archicad-library-lcf/
Marc Corney, Architect
Red Canoe Architecture, P. A.
