Learn more
string location in text file
Hi all,
I'm working on a Keynote tool for a client and wondering if anyone knows the script for returning the row and column numbers of a specific string.
Returning the string using the location is easy, but can I go the other way around and return the location using the string. It sounds like it should be straight forward but i'm a little sleep deprived at the moment.
Thanks,
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
1 Reply 1
Frank Beister
STRSTR()
