Find the perfect object, manage libraries, create custom objects
Articles
About BIMcomponents.com https://youtu.be/qcvmK0AkXxE 1. What are the main objectives of BIMcomponents.com? Provide Full Visibility for Existing GDL Content Contrary to conventional wisdom GDL objects do exist in large bulks but they are spread all over the Web. We set the vi...
  • 10026 Views
  • 0 likes
  • 0 comments
The Embedded Library is a place to store project specific content within an ArchiCAD project. Textures and objects that are going to be used again in other projects should be stored in an external library. Follow the steps below embed content into the Embedded Library. Note:...
  • 6416 Views
  • 0 likes
  • 0 comments
In certain situations having a full library in an LCF is more useful than having the library in its original hierarchical folder structure form on your hard drive. Such situations are: Library Parts are not modified or not to be modified. Let us say you have an Office Librar...
  • 18887 Views
  • 3 likes
  • 0 comments
