trouble customizing NCS DrawingTitle 11
Erika Epstein
I am customizing the NCS DrawingTitle 11 to match firm standards. I've been able to do all but the following two items. See screenshot for goal.
1. find where to delete the colon after the word SCALE. In the parameters I only have SCALE written with no colon and I can't find where in the scripts the colon is being added.
2. have the written scale e.g. 1/4" = 1'-0" show centered above the SCALE
The original had the written scale after and in the same line as the SCALE. I duplicated the script under GOSUB 500. I deleted the drawingscale from the 1st line so only stex [the word SCALE] will show. This worked fine.
In the duplicated portion I deleted the stex hoping the written scale only would show, as well as adjusting the Y value so it would be centered above SCALE.
The problem is both sections of text now show SCALE over SCALE. If I comment out the stex original portion the written scale shows correctly in the correct location. I believe the problem has todo with the original script uses 'drawingScale' to call both the stex and the written scale. I am at a loss as to how to get the second part to call the written scale.
500:!Show "SCALE" and Drawing Scale
set style "styleDrawingScale"
pen gs_drawing_scale_font_pen
!! ORIGINAL SECTION OF TEXT WITH that used to read drawingScale = stex+ drawingScale========================
drawingScale = stex !!!"SCALE" !ERE change to put drawing scale above the word "scale"
if (GLOB_CONTEXT = 22 | GLOB_CONTEXT = 28) & (gs_GLOB_MODPAR_NAME = "gs_drawing_scale_pos_x" | gs_GLOB_MODPAR_NAME = "gs_drawing_scale_pos_y") then
textWidth = stw(drawingScale) * PAPER_TO_MODEL
textHeight = drawingScaleFontH
textAnchor = anchorDrawingScale
gosub 1300
add2 anchorX+2*rc, anchorY
rect2 posX+2*rc + gs_drawing_scale_pos_x+diam+0.0064, posY + gs_drawing_scale_pos_y-0.002,
posX+2*rc + gs_drawing_scale_pos_x+diam+0.0064 , posY + gs_drawing_scale_pos_y-0.002 + textHeight
del 1
else
TEXT2 posX+2*rc +gs_drawing_scale_pos_x+0.0064, posY + gs_drawing_scale_pos_y, stex!drawingScale !!!!!!-0.002
endif
!! DUPLICATED PORTION OF ABOVE with stex deleted===================================================================
drawingScale = drawingScale !!! drawingScale
gosub 1300
del 1
else
TEXT2 posX+2*rc +gs_drawing_scale_pos_x+0.0064, posY + gs_drawing_scale_pos_y+ 0.5*titleHeight, drawingScale !!!!!!-0.002
endif
RETURN
Can someone point me in the right direction?
Thanks
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I changed the parameter as well to "SCALE", without the colon. It didn't change the existing drawings so I picked one of them and turned off the drawing title. Then I went back in and turned the NCS Drawing title back on. This fixed the problem. Also any new drawings that I placed with the title showed the text properly.... Only one part of your problem but it's a start.
Doug
Hi Erika,
Unfortunately I don't have time to go any further with this tonight, but you might be able to use what I've gotten so far.
500:
drawingScale = drawingScale !!!"SCALE: "
gosub 1300
add2 anchorX, anchorY
rect2 posX + gs_drawing_scale_pos_x+diam+0.0064, posY + gs_drawing_scale_pos_y-0.002,
posX + gs_drawing_scale_pos_x+diam+0.0064, posY + gs_drawing_scale_pos_y-0.002 + textHeight
del 1
else
textWidth = stw(drawingName) * PAPER_TO_MODEL
TEXT2 posX + gs_drawing_scale_pos_x+diam+textWidth, (posY + gs_drawing_scale_pos_y)-1/8", stex
TEXT2 posX + gs_drawing_scale_pos_x+diam+textWidth, posY + gs_drawing_scale_pos_y, drawingScale
line2 0, 0, .25", 0
endif
RETURN
Doug
PS. Ignore the line2 statement at the end....just looking for 0,0
Erika Epstein
Doug,
Thank you very much.
Your posted text was just what I needed. I was able to adapt from your example to get the placements I needed.
Have a great day.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
