value lists
am i able to set a default value out of list of values
4 Replies 4
Frank Beister
Yes. use VALLUES
VALUES "a" 0,1,1.25,1.5,2,5,custom
This adds a value list to the width of the object.
ive got a basin part that has 4 types of basins
square, round, etc
ive predefined a series of sizes + a custom to override
if i toggle between basin types the size is automatically defaulting to custom which is set at the previous basin size
when if change basin i need to set a size in the selected basin value list
square, round, etc
In parameterscript :
VALUES "basin" "t1","custom"
IF basin="t1" THEN
PARAMETERS a = 1.2 ! Set parameter A to 1.2
LOCK "a" ! Lock parameter A to be edit manually
ENDIF
IF basin="custom" THEN
! nothing needed here
ENDIF
David Maudlin
damien:
If all you want is for a particular option in the value list to be the default value, open the library part, in the main library part window set the value parameter to the preferred default, and then save the part.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
