Cosminn
wall accessories parameters
Hello everyone, i want to create one object, type "wall accessories", but i need to know all the parameters of the wall. from where can i find? for example, if i want to use the real length of the wall (even if there are embedded columns)
Can i?, or the core thickness, etc. Thanks in advance.
Sincerely,
Daniel
2 Replies 2
Frank Beister
You have to set the correct subtype. Then you get blue parameters, which are filled, when object is associated with a wall.
Cosminn
Thank you
Sincerely,
Daniel
